I've got a Holley blue pump, i wonder if it would keep up
I think the blue is preset for 9 psi. At Wot it would probably go down to 6 or 7. I think your fine.
IMO, the holley is better that a carter.
I was checking ou the Holley black pump and Sumitt racing says it's alright to run the black pump with diesel, As long as it does not have Bio-diesel in it, says Bio-diesel will eat the seals up, Monte
I had the issue with the fuzes blowing, found AirDog pump to be seized. Called Pure Flow, gave them my serial number, yes I filled out the warranty card. Had system in place for a year, about 10,000 miles on it. Any way, they sent me a new motor with install instructions. New motor is quite. Old one always buzzed and whined since new, was it bad all along? I see 17-18 psi on my fuel gauge which is tapped into feedline just before CP3 pump. With it being 6 degrees the other morning, never even had a hiccup. I'm sure the other systems and pumps work well, I can and will say, Pure Flow stood by their product with excellent customer service. I believe the rep's name I spoke with was Kyle.
