I just purchased a set of air horns with a large compressor and air tank setup.
The compressor is rated at 15 amps and comes with a 20 amp in-line fuse. Directions say to wire to ignition switched 12volts. I wanted to tap into the blower motor, but it is only a 10 amp circuit. Anyone know where I can wire into 12V switched, 20 amps?? Can I do it another way?? How are you guys wiring up your compressors. Any help is appreciated.
