Hi! So, I installed some air horns on my truck. Right now I am pulling directly off the battery, bypassing the stock horn. Power runs through the firewall, through a wire-wrap cord to a switch box which houses a lit LED toggle and a pushbutton momentary, then back though the firewall to the 12 volt solenoid.
What I would like to do is have the option:
1) Like it is now, stock horn separate from the air horn
2) Air horn and stock horn working simultaneously
All I want to do is switch between the two
What do you all recommend as the best way to go about this?
Be as specific as you can with the electrical terms. I know most but not everything.
Thanks!
Nick
Thanks!
Nick
