Air hose - dual rear wheels
Differential oil
Gauge Pod for Dash
I am looking for a device that will make it more convenient to check and adjust air pressure in the dual rear wheels on my Ram. I have seen a few advertised but wondered what the experience of others has been regarding these. Of interest also is whether they significantly change the balance of the wheels.
Any help will be appreciated.
2001 3500 QC SLT, 5-spd. , 3. 54 LSD, towing 2000 Cedar Creek 30'
I had the same questions two weeks ago. I bought ($30-40) a kit that has hoses that extend to brackets on the hub to get access where I could reach it. The instructions said to mount the tires with the valves 180 degrees apart, to offset balance problems.
I installed the kit, and the jury is out on balance problems.
Leo
2001 ETH/DEE 3500 QC 4x4 SLT, Driftwood/Agate, 3. 54 gears w/anti spin, camper special & towing packages, sprayed bed liner, BD brake w/shift switch & gauge, egt/boost gauge, 2-low switch, weatherguard 5W tool box, Geno's towing mirrors, looking for nerf bars.
Leo -
Who makes the product you purchased and who did you buy it from? I have found some hoses in the Camping World catalog. I'm not sure yet if they will work since they are really aimed at motor homes and such.
Mel
Lembaar, I bought the ones from Camping World. The manufacturer states on the pkg. that they are not to be used with rubber valve stems (our Rams). Made sense to me after feeling the weight of the extensions. The clips provided would not have made for an easy install either. I returned them.
RonL
98 3500 QC 4X4 Int Blue, Unbombed 6BTA5. 9 12V,
Auto 3. 54 LSD, PIAA Pro90's, Tonneau, Running Boards, 5K Air Bags, Hadley Air Horns, EGT/Boost/transmission Temp Gauges, Cobra / K40, Valley class V, Bugflector II, Bedliner, Tow Hooks, Cup Smoothie, Meg's turn-down tip, SS Fender Flares... .....
99 Lance 1110 Slide-On Truck Camper
Mel,
I got mine at a local camping supplier. They come in rubber or steel sheathed (I got rubber), and in three or four variations, depending on the wheels and wheel covers.
For the Ram SLT, the kit with two hoses (one with a right angle adapter), and two 90 degree brackets to be pop riveted to the hub is the right one. Comes with rivets - provide your own tool.
Later I looked at Camping World, and they didn't have that specific kit.
Leo
Thanks Leo. I'll check at the camping supply shops nearby.
Look for "Air Masters" by "Wheel Masters".
Part number W. M. #8001, work great!!
WHEEL MASTERS
P. O. BOX 60910
RENA,NV 89506
(702) 972-7888
Regards Pete
99'3500,quad cab,4X4,a/t
3:54,all the right packages!PROPER VALVEMENT
Be careful when attaching extensions to outer rims, make sure they are secure. I bought a generic set with the steel lines and they slung loose and pulled my valve stems out of my inside wheels. I admit this was due to installation error. But just wanted to let you know what can happen.
Todd
99' 3500 SLT Med. Red Metallic 163" W. B. Cab & Chassis with custom haulin' bed, sleeper, rear light bar, stainless runnin' boards, stainless cow catcher on front, 5" dual stacks behind sleeper, hadley "bully" air horns, galaxy 44 c. B. with texas star 350 and wilson 5000 whip, etc... ...
I have the stainless lines from camping world installed on my stock rubber valve stems since 96 and have had no problems. I am now on my 2nd set of tires. No balance problems either.
1996 4x4 3500 4. 10 5spd, Banks Power Pack with 4" exhaust, Cummins exhaust brake, US Gear overdrive, Grover air horns, Mag-Hytec cover, and more.
