That is a very vaild question - let me try to answer.
From what we can determine, the factory was mostly concerned with keeping everything as quiet as possible - it doesn't seem like the factory was necessarily concerned with power as much as quieting down as much as they could.
That said, the factory plastic air box assembly and the rubber corrugated flex hose are designed to essentially eliminate turbo whine and the sound of rushing air - that's about it - not much was designed to make power. The other big noise-reduction comes from the under hood matting. Our first truck was louder than our current 1st gen, and the difference is the under hood sound insulation. If you don't have that insulation the turbo whine will echo through the hood and your hood will turn into a great big speaker. Even I will admit that my first 1st gen was right on the edge of being too loud, and it did not have the hood matting. Our current 1st gen does and it is much better - just right.
Overall boost will not increase with our Intake. Once a turbo is spooled up, aftermarket or stock, it ingests air just about regardless of if there's an airbox in place or not. But, what does change is when the boost begins to build. Because our Intake is smooth-bore, and because the filter can bring in air uniformly around the filter, the boost builds sooner than the factory assembly - roughly 100-200 rpm sooner. There are no appreciable gains in top-end power over a stock system, but there is an appreciable difference in low-end power because it comes on sooner than stock - a big plus for the tug-boat crowd. There is also a small increase in fuel mileage as a result of the increased efficiency of the AFE filter over anything stock.
There are bigger improvements with upgraded fuel and exhaust systems as well, especially exhaust. I have a hard time getting past 1200* when pulling big weight trying to maintain highway speed. Just when the pyro nudges 1100-1200* the boost gauge climbs and maintains a nice pyro temp.
For sure there will be increased turbo sound, which is sometimes a desired gain :-laf. What I might recommend is if you want to keep our Intake system in place but reduce the sound you could add the hood insulation (if it isn't there), and for more you could build a shroud around the filter, not too close but more or less similar to the factory box. The turbo whine comes from both the filter and through the Intake itself. You could also wrap sound deadening insulation around the Intake itself - I think that would make a fairly big difference. We looked at several versions of a shroud but most of our customers preferred not to have one.
There does not seem to be any adverse affects from rain, water, snow, etc, with the system. In fact the factory air opening seems to direct rain and 'spray' from the front grille directly into the airbox more than our system would. And if any water gets on the filter it will simple atomize with the incoming air and cool off the exhaust - a natural version of water injection.
Hope that answers some questions. Thanks for the inquiry.
- Sam
ASA Modifieds
