So the MAP gives a temperature? I thought it provided manifold pressure input to the ECM?
Just because it changes does not mean there is osmething wrong. Very true, but if the OP is in tune with his truck, as I am with mine(and I know you are also), any change is suspect.
Too many failure points to pin point an issue or even say the operation is not "normal". I agree cerb, lots of possibilities to try and pinpoint from a forum, but, you can state it is not "normal", and it still may be in acceptable parameters, however "you know" all is not correct.
