I hope someone help me with this. I have air trapped at my fuel press sensor. I replaced the banjo bolts with the high flow from Geno's, then installed tapped bolt at fuel pump, then installed snubber to eliminate any pulsing, then installed the sensor. Do I also need to add a extension with a grease gun hose. My gauge still is bouncing, and if I bleed the line at the sensor it will clear up for a couple of days. Do I need to install FASS system. Has anyone else had this problem?
