Archived airbag light on & no guages or tach
Archived 1000 Miles From Home With Trans Problems!
Archived Axle shaft hub nut size???
My 98 12V had been resting for about 3 weeks when I went to start it the other day but the batteries were dead. (They were very old) I replaced the batteries and it started right up but I have NO guages working, NONE, and
no tach either. After you start it the warning lights behind the speedo light up briefly but then go out I guess as they are supposed to, however the airbag light comes back on and the chime starts.
Also the digital odometer keeps flashing the miles up about every two seconds or so.
I dont believe the alternator is putting out OR the current is not getting through to the batteries because the interior light will not brighten after starting the truck or. A friend was following me and said the brake lights were not working either!
Will someone with experience with these symptoms tell me what my problem is? All ideas apprieciated!:confused::confused::confused:
I can only give you a tip that is not directly based on experience with that year Ram: Disconnect BOTH batteries for 10 minutes and then try again. My guess is that the computer is screwed up and maybe that will reset it.
Also, take a carefull look around for critters that may have chewed on the wiring.
NScott,
Have you checked the fusiable links that power that side of the electrical circuits. Usually located coming off the starter postive battery post or some where at a junction box. Had one several years ago do that and took forever to locate it without a wiring digram. Sounds like a loss of connection somewhere. Hop this helps.
JJones, 96', 5spd, EGT and Boost gages, all else stock. Purchased used in Febuary 09' 368K.
