I have had the Air Bulldog induction hood on my '98. 5 Black Sport since the beginning of last July. The looks I get with this hood are unbelieveable!
I immediately noticed an EGT drop of approximately 75 degrees F. (POST turbo) after the installation of this hood. I wish I had had the pyrometer thermocouple installed in the exhaust manifold back then... it would have been nice to have more accurate before and after data to convey to you.
Doug Hofeldt designed and produces these fine hoods. Doug can be reached at: hofedoug@ida.net (email) or (208) 232-2469 (phone).
I think you are going to find that you will need to lose the OE turbo with the 9 cm2 turbine housing in order to reduce EGTs on an enhanced engine that sees towing. You might want to call Piers at BD Diesel Performance about the HX40 Super Turbo. If interested give Piers a call at: 1-800-887-5030
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass, Optima Yellow Tops, DD3s and DD TTPM, Aeroquip AQP braided s/s fuel hoses, Banks High-Ram intake manifold and 14 cm2 turbine housing w/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
[This message has been edited by John (edited 02-21-2001). ]
