The current harness is wired to the alternator and ECM. It runs with the ignition on, but blows the fuse 15 seconds after I start the engine.On the AD\FASS the pressure regulator doesn't turn the pump on or off, it just bypasses fuel back to the tank when pressures exceeds its setting. That happens whether the engine is running or not, the AD\FASS delivery almost always exceeds demands so the regulator is always in play engine running or not.
The only real difference between engine running or not is the electrical system load. It may also depend on how the AD is wired; direct to key-on power and always on, or, run thru a relay that the ECM is activating. The latter adds wiring components and the ECM lift pump circuit to the equation, the former is just a battery draw with fewer components.
The only work I've had done in the past month or two is new serpentine belt, water pump, idler pully and tensioner.
I bought the parts from Geno's and a local shop installed them. They are the same shop that did my injectors last year and I have been pleased with their other work. A new issue has reared its head now since the new harness has been installed. The fuse for the HVAC has blown and blows every time I replace it.
Maybe someone can suggest a good/better mechanic in or close to
Corpus Christi, Texas?
