I kinda finished installing an airdog, 56 gal. Titan tank and a modified fuel bowl from high desert Ravelco. Its not working right. I am going to list the problems I am having. Any help would be great.
1. The o-ring seal used to seal the fuel bowl is leaking?
2. The airdog is sucking air I think from the water seperator.
3. Could 1 and 2 be related? Would that leak around the seal make the airdog suck air? It has a drawstraw that goes to the bottom of the tank. Could it be leaking were the tube is connected to the 90? Has anybody experianced that?
4. When I energize the airdog its load as hell cause its sucking air. If I unscrew the water seperator a couple turns it quiets down just like the troble shooting sez it would do. I also can see the inlet hose jump a little bit when the presure is released by umscrewing the WS.
5. I now want to try and Take off the WS like the trouble shooting instructions say, to check the seal on the WS. Cant do this cause it wants to drain the whole tank. I am pretty sure its doing this cause it drained out over 4 literes of diesel?
6. Is this normal? How do you change the WS or the filter if its trying to drain the whole tank?
7. How much did I screw it up?
8. What will it take to fix this problem?
Sorry for being so long but its driving me nuts!!
