I use a dually air chuck and tire gauge, and even then I did some Dremel work to get a little more clearance where the chuck goes over the valve stems. Also, on the outer wheel, I use the non-pressurized valve stem extenders like those used on cars with full wheel covers. They are about 2" long and make it a lot easier to reach. I use a length of 1/2" rubber hose to remove and install the valve caps on the inner wheels.
I had the braided metal valve stem extenders on my previous dually. They worked OK, but not really any easier than what I'm doing on my current truck as described above.
Rusty
