Aisin behavior question
Latest Software Update service bulletin 18-043-17
Ive been around the TDR a lot longer than you snoking, and I don't remember you being appointed moderator....we strive to be helpful and courteous and you have been in the past. Not so much in this case....I'm just trying to get a TSB number...if you know it...great. I'd like to have it. If you don't...then I reckon there is nothing more to say about it.
I have been a member since 2001 and I think SNOKING has been here around as long. He has a LOT of good info. Either read it or don't.
I don't know Ron, I joined in June 2001, so have not been around very long. I gave Flash the info to PM Bob4x4, who got me a list of TSBs, but I guess he does not want to do that, and is waiting for a bother TDR member to come forward, whatever a bother is!
I guess he forgot that what I told him in post #2 also?
I am having similar issues with my 2017 Ram 3500 with Aisin transmission. I found TSB 21-004-16 Rev. A-2 which from the description seems to be the most recent version. Does anyone know for sure if it's the right one? I have found it best to be an 'informed consumer' when it comes to having vehicle service work done. Thanks
Again, this is the list of TSB that I had done in January. Coming home from Arizona I no longer had the hunting and it held 5th better on hills and when it shifted down it stayed there until I crested the hill. I was running 60 in 5th with 6th locked out, towing 5th wheel, combined wieght 24K+. Going down last fall it hunted a lot on hills and I had to lock it in 4th until I crested the hill.
TSB 08-82-16 ITBM
TSB 08-044-16 RFH RF Hub
TSB 21-004-16 TCM
TSB 05-013-15 ABS
TSB 08-017-17 BCM
TSB 18-037-16 PCM
Again, this is the list of TSB that I had done in January. Coming home from Arizona I no longer had the hunting and it held 5th better on hills and when it shifted down I it stayed there until I crested the hill. I was running 60 in 5th with 6th locked out, towing 5th wheel, combined wieght 24K+. Going down last fall it hunted a lot on hills and I had to lock it in 4th until I crested the hill.
TSB 08-82-16 ITBM
TSB 21-004-16 TCM
TSB 05-013-15 ABS
TSB 08-017-17 BCM
TSB 18-037-16 PCM
Thanks. I have my truck scheduled to have the updates done on Friday.
TSB 08-82-16 ITBM
TSB 21-004-16 TCM
TSB 05-013-15 ABS
TSB 08-017-17 BCM
TSB 18-037-16 PCM
Where do you pull up those TSB codes? I can't find anything online that gives them, though the NHTSA site used to.
