Soooo, someone on this board did question whether or not the Aisin rear diff cover pan would work on our axles. This is a thread confirming that it certainly does, I got the inspiration from the Chevy guys going out to the RAM dealerships or Driveline shops online buying our cover and putting them on their trucks. Here is my write-up on my install on my truck, enjoy.
The tools n' the parts comparison
Gaskets are identical
See (They're stacked on each other)
Painted the filling bolt. I see lots of these covers with this bolt rusted so I wanted mine to keep looking good
The old rear diff cover, 18,200.00 miles on that cover. Note the two long studs on the upper left of the housing. My truck doesn't use them and I don't know what they're for. But the new Diff cover has options on using 2 studs in that packet of bolts, or using 2 more Torx bolts. I decided to keep the studs in case I ever need to mount a line to it for something, like an e-locker or air locker if they make them for our axles.
Letting the cover drain. I let it drain for about 2 hours. Leave the bolt on top so the cover doesn't fall on you. I just went around and broke all the bolts loose first and then removed all the lower bolts.
Interior of the pans side by side. Note how there's directing vanes cast into the aluminum
Notice how much fine metallic stuff is on the pan and bolt
Inspect those fill plugs every oil change as the stamped cover is also magnetic!
Nasty
Ready to go
Great wear pattern, I'm happy I did this. Re-assured that my diff was wearing in well
I'd rather have this than truck nuts any day of the week! I love the rear end shine!
Just a last note. I torqued the bolts around to about 24 ft-lbs.
I torqued the fill bolt to 30 ft-lbs.
Also another note, since the owner's manual doesn't tell you, the rear end takes about 4 quarts and then the oil starts coming out of the hole. This is with my truck parked on a slight incline (front tires 3 inches higher than rear tires, I know my driveway well). Manual specs say you're good if you are 1/4" below the hole, +/- 1/4". So filling to the hole on a slight incline, I figure I'm just a little below it on perfectly level ground.
So there's a quick write-up. This is less than half the price of a mag-tec or any other pan, there's a website where you can pick it up for like 95 bucks or something. I bought mine from the dealer for 130 or so bucks.
Nasty
Ready to go
