Ozymandias
Unfortunately it doesn't change the lockup speed for the Aisin.
Uh that's sad, so the good old 48RE is smarter than this brand new unit.
Wait a minute, it doesn't even lock up in Second gear?![]()
Whats the highest transmission temps you have seen slow mo dirt road driving . Your not pulling your camper all the time your hunting right . In 4 h not 4 low . I would just watch the transmission temps and stop if it really started to go up and put it in neutral high idle and let it cool . When it got to about 190 would be on the side of the road. I see folks go backcountry here pulling way heavy 5 th wheelers slow over steep grades in a panic because the transmission alarm goes off. I tell just find a wide spot pull over set the brake neutral and fast idle let in cool down . Works for them it seems . But it does really scare them and freak them out in the middle of now where being from Illinois Nebraska etc etc flatlanders mostly sorry
Not in 4LO.
For some reason the programming for TQ Lockup is not using TOS like a 48RE does, but rather it appears to be using wheel speed and has the same criteria for lockup in HI or LO rang...~20-22 mph.
The 48RE is just simpler and doesn't care about any gear changes after it, so HI/LO doesn't effect TOS. I really hoped the Aisin was this way, but neither my 18 or 22 will lockup any slower in 4LO.
I'll bet it an engineering oversight with ow its a stand alone controller, which actually surprises me a little since it would need a VSS input for operation instead of just a TOS speed sensor like the 48RE uses.
If you do the trans service (oil drop)yourself etc, MAKE sure you reset the codes BEFORE you shift into gear. When you change the oil, it throws a code and causes the AISIN trans to shift like GODLIZZA who wants to break your driveshaft in two. Once you plug into the OBDII port and clear the code, your golden.Certainly glad you chimed in John. Don’t really know when mine was built but at almost 23 k miles now it shifts like a dream. No issues .Also I have a warranty and max care no worry’s
I just went out and went on a lonely road no traffic and put my truck in 4low and drove it around using the steering wheel shifter in 2nd and 3rd gear up a couple good grades and down .Ten miles a hour speed rpm’s I dont remember about 1500 I think this a sweet pulling spot for the truck . transmission temps went up a wee bit but stayed at 163 normal 30 degree day. But the problem I really see is you don’t really know if you in lock up or not. Would be nice to have a light or something wouldn’t it. So as I recall from last summer hauling heavy load and using the exhaust brake in tow haul mode the brake would drop off at about 12 miles per hour which means the torque converter went out of lock up If that’s true and run at any thing above 12 mph you should be locked up. Hard to tell the lock up it’s very faint. My old 99 DTT built transmission you could really feel it and it was at 20 mph . Oz says his is at 8 mph which is pretty low Then theres tow haul mode wonder how that enters into all of it.A transmission man might be able to put a lock up light on the transmission but then there’s the warranty. Maybe you can plug something into the port that would tell you lock up . Interesting topic as we wait for spring in Alaska 2 months away
That's interesting as the ECM knows that the truck is in 4Lo and changes the fueling table and reaction to throttle input. But apparently doesn't tell the transmission about it.
It takes so long for the trans to cool at idle that I prefer to keep moving a little slower
