AIT Clean and changed Thermostat
duramax diesel
New Ford G2 - boy the ad boys love em....
IAT Clean and changed Thermostat
Today removed and cleaned IAT I have 43,000 and use a Jacobs exhaust break almost all the time. It was black and dirty with oil/carbon. Did not look like it was that bad. Also put in 180 degree thermostat and flushed and filled Shell Rotella ELC. Temp is lower as expected but even though I used a Thermostat from from Cummin's the temp still overshoots then drops below normal then settles out around 180. Don't know what part of the change did it put my tach settled down as it used to jump around about 50 rpm now rock solid. I like using exhaust break even though not towing. Guess will have to limit it's use. Ought to have better a place to locate the IAT!!!!
Alan Reagan ~ your right IAT fingers going faster than my mind which does not take much anymore!!!! I fixed my original post too. :rolleyes: :{
I know that some guys out there have relocated IAT to the intake horn. But they would have to let you know how it turned out.
Les
Relocated to air box. Took out filter minder, plugged in (new) IAT sensor in hole with rubber grumit. Left old IAT sensor in place to fill hole, took #16 wire plugged into IAT connector, blacked taped connection, went to auto parts store, got new IAT connector for $9, connected the two #16 wire leads to new connector and your'e done... No more stumbling, no more plugged IAT sensor, now reading ambient air temp, no drilling into intake horn... etc. etc. etc.
Total cost $35. 00 including wire etc.
Does it work , you bet your sweet _ _ s.
Steve
