Alaska in September
WyoJim,
Well, it sounds like you have given this trip some thought already
and your itenerary sounds pretty good. The trip from Dawson over
to Eagle then on to Chicken could possibly run you into a little
snow so I would prepare for that eventuality. That route is not
maintained in the winter and I'm not sure when the maintenance
ends so you might want to check that out. It becomes a groomed
snowmachine tail in the winter from Tok to Dawson. A lot of the
tourist traffic ends around Labor Day so that should make your
travels a little less harried. If you can't get into Denali Park you
might want to consider taking the Denali Highway from Cantwell
to Paxson its close to 140 miles of gravel road and used a lot by
hunters in September but it will put you into some fairly wild areas
again it gets you up in the mountains where you might run into
snow so be prepared and by the way getting up in altitude here
is different than in the western states in that 4,000 feet would be
extreme for a highway and tree line is around 3,000 feet. Here's
a link you might find helpful;
http://www.dot.state.ak.us/stwdplng/planresc/road_cond.html
I'll try to answer any other questions you might have.
Gus
