2nd Gen Non-Engine/Transmission Alignment in Salt Lake City
2nd Gen Non-Engine/Transmission Front End Sag w/plow
Hey, anybody from the Salt Lake area know of a good shop the get a front end alignment? Most of the shops I've called say their equipment won’t accommodate a quad cab with long bed. :confused:
Thanks for advice.
Steve
The alignment shop you called probalby was thinking 4 wheel alignment instead 2.
Four wheel alignment is a rip off and should be the last option if rear tires are wearing wrong.
Alignment Specialist @ 972-1105 2141 w 2100 s If it has wheels they can align it. They have a flat floor, Most dealers there rack will not accomidate a long wheel base.
Marv.
I will fourth alignment specialist. I had a ton of play in my steering before taking it in and when I started to drive it home it was like a new truck. They will show you the problem and then you can make the decision on what to do and they are not over priced. Andrew
Thanks for the advice. I callled Alignment Specialist today and made an appointment based on all the positive feedback. I'll let them know what an impression they made.
Steve
I brought this thread back up because I wanted to get a little more info before I just assume that I need alignment.
My truck (in sig) is wearing the outer edge of the passenger side front tire off. The drivers side appears to be OK. What could be causing this? I just rolled over 52000 miles, and had it aligned by the dealer in American Fork in the spring of 08.
Thanks,
Wes
