I hope someone can answer a question on the toe in measurement for the '03 3500. I've checked threads and have only found the specs in degrees,not inchs like I need. We installed the Mopar steering upgrade and thought we measured everything correctly,turns out we didn't. My steering wheel isn't straight and the trucks is pulling to the right. I realize I need to go to the alignment shop,problem is I need to do my upper/lower BJ's and don't have the cash right now,plus I want to install the Spyntech kit at the same time. I know if we have the correct measurements,I can continue to drive the truck till money is flowing again.
Thanks fellas,
Casey
Thanks fellas,
Casey
