I have been meaning to do this fix since I saw Eric's post. I had already replaced the oil splattering bottle with a breather that was baffled and had breather (k&n) on it that I used to use on sand cars, which had to be mounted on pass fender wall. It worked good, but I got tired of having to remove it to get to oil filter during changes. Since I was getting ready to adjust the valves and cover was to be off anyway, this was going to be a good time. Eric is right, this was a cinch. I made sure that the hole wouldn't interfere with any valve springs and such. Drilled a 1/4 inch hole and used a step drill to go up to 1 1/4 inch hole for grommet. I then used my small 2 inch grinder to remove the ribbing enough to allow grommet to fit flat. I bought a Moroso valve cover breather P/N 68781. Chromed and all. It took a 5/8 hose that is run down away from headers, down pipe, etc. . and tied into the bracket on frame. Eric good post and works great. Oo.
