Engine/Transmission (1994 - 1998) all done with the new timing gear case
Man, what a job!
took me almost two weeks and most of that was waiting for the local guy to tell me he can't find any parts for me. :confused: I checked back with him for over a week and he never did find anything, so I went to the Cummins web site and found a "real" Cummins shop about two hours away and drove there after a phone call to make sure they had the parts, and had everything in one day. :D
I wanted to smack that first fellow. You could tell he just did not want to put any effort out. I stopped back at the local shop on the way home and asked if he had any luck finding parts and he told me that I would have over $600. 00 in parts and Cummins said they were all out of the gear cases. :--) I said that's awful peculiar as I just got back from Cumberland Cummins in Fairmont, WV. and they had everything I needed and I got it all for $450. 00.
He did not have much to say after that so I just left. :rolleyes:
Anyway I did not get to adjust the timing. I just set everything to TDC. It started right up after the usual bleeding if the lines. I only have to tighten the fan nut as i don't have a wrench to fit the nut.
What size is the Fan nut and is there any wrenches specific to this task?
I loosened it with a drift punch and it came right off.
Had close to $900. 00 in everything. That includes new #6 TST plate and 60lb springs and several other odds and ends that have needed attention ie. hoses, filters, fluids, other gaskets, and two new sensors. I broke the oil pressure sensor putting the inj. pump back on by myself.
I have learned alot about my truck and feel more comfortable about it now.
Next thing is a new performance transmission! Oo.
Glad you got it running again. The fan nut is 36mm and yes you can buy a fan wrench set that will fit your truck and other makes/models but they are a bit pricey. The fan doesn't need to be real tight, you could probably give it a few wacks and leave it. I have read where some guys just let the engine do the tightening.
made my own wrench. piece of flat stock, piece of pipe, hammer and whamo off it comes. REDNECK, maybe ,price? pricelesss!!!!!!!
