Shortshift said:If you go with the FASS, I recommend also adding the Vulcan 1/2" line kit, and installing a new 1/2" pickup tube in the tank to replace the restrictive junk that is killing lift pumps to begin with. With a new pickup tube, FASS pump, and free flowing 1/2" lines, you can set your pressure down at 13. 5 psi, and never be able to pull it below 12. Easy on the VP44 injector pump, and easy on the FASS. Anything short of that, and its not done right yet.
blacksheepdiesel said:The filters on the Airdog are not proprietary... they are made by Fleetguard. I have the filter numbers available and they are quite inexpensive. I use the 2 micron filter on my truck.
To underscore the problems that FASS has had there are threads on this board that highlight those issues. I have never seen an Airdog issue thread. Not making light of FASS or those who have had issues with it, just pointing out what seems obvious to me.
Trent
CCahill said:With all this being said... Who are you buying the FASS setups from ?
