I moved this from the parts and accessories section. Hopefully it applies more here.
I just finished the first part of the install of my Power Vision Mirrors. My first impression is that they are very nice mirrors. I do have a couple of questions for those of you that have installed them on your trucks. .
When I torqued down the 3 bolts the excess of the foam gasket on the outside of the door squeezes out from around the mount. Did you guys attempt to trim it flush or leave it as is.
I noticed the very top edge of the mirror mount where it comes to a point does not sit flat against the sheet metal of the door. There is approx 1/8 gap. I assume this is due to none of the bolts pull directly in on this area of the mount. I tried loosening all the bolts and retightening the top one first but it does not completely pull in the top. . Is this normal or am I doing something wrong?
Tomorrow I will finish wiring up the switch assy and will let you all know how it comes out.
Thanks
Frank
__________________
Thanks
Frank
__________________
