I'll put the symptoms out here and hope to get some advice.
Started the truck this morning to warm up with no problem. Ran for about 15 minutes before I left for the job site. Now I don't remember exactly when the "check Engine" light came on but as I accelerated away from the house, I could tell she was running poorly. I went about a half mile and decided to return to the house. I pulled the following codes using the "key" method.
0122 APS low voltage
0500 No vehicle speed sensor
1693 companion code.
I saw in an other post for the 0500 code is that the speed sensors are not agreeing on the speed. I do have a problem with the right front sensor that I haven't had time to address. Also, I will be replacing the front pads as I can hear a faint groan when I break.
Anyhelp is appreciated. I'm 150 miles from home without my manual and very limited tools. The closest NAPA or any other auto parts is about 15 miles so I have to make the trips count.
