Alpha OBD and 2018 RAM 3500 Aisin trans
Wonder what kind of oil and filter the dealer uses.
Edge Juice with Attitude
Does anyone know if Alpha obd will work on a 2018 RAM 3500? I have a U1439 after putting 35" tires on. I took it to the dealer after they told me they can calibrate it for the tire size change. Later said they can do anything!!!!! Thanks
YES it will! You'll need a security bypass cable to get into the ECU. This is the cable that I got for FIL truck and others have gotten as well,https://www.kaodtech.com/product-page/security-module-bypass.
AlfaOBD is Android or Windows OS only. You'll also need a way to connect to OBD on the truck. I use the MX+ Bluetooth to my phone. The MX+ also gives you a generic scanner also for you other vehicles if needed. You enjoy what Alfa will bring to the table for your truck. Just remember to save the original config file so that you'll have a starting point to return to in case of an issue. Enjoy your truck!
