Get the gasket and front crankshaft seal. It is a fairly easy job. Some people rave about the "KDP jig" that drills through the front housing. Personally, I say that is only a "half a$$ fix" because the front housing bolts have a habit of working loose also. I have tabbed two KDP's and inspected several others (that were already gone) and the bolts that hold the housing to the block were loose on all of them, wheather the dowel pin had come out or not. If any of the bolts were to come out, I would say it would cause as much or more damage than the KDP. Get the right parts, get (or make) a tab for the dowel pin and Locktite the bolts that hold the front housing to the block and do the job right. It will pay off in the long run.
