Well, most of my information is from websites out there. For information, check out the
National Biodiesel Board.
For continuing discussion and howto information, join the biofuel group on at
Yahoo . Just do a search for "biofuel".
For the recipes, head to
this site and click on Biofuels on the left. I'm using the FoolProof recipe at the moment without much luck. I'm making a lot of soap, and some diesel. The diesel I have make is good, clear, ph balanced stuff. I'm just not happy with the yield per liter of stanky veg. oil yet. I have 5 different test batches going right now, and am building a reactor out of an old electric water heater that should be able to pump out 30 gallons every 24 hours.
I should be getting nearly a liter of clean diesel for each liter of veg. oil I brew. There's really only 3 ingredients needed to start bewing, and some basic chemistry gear. Here's a little list you should consider:
Chemistry gear (use metric stuff, easier to follow the recipes):
- Thermometer
- graduated cylinders
- 2 liter beakers
- digial ph meter (or papers, either will work)
- 5 gallon buckets
- reactor - I use a 16 gallon can that used to contain gear oil
- heat source - need to get up to 55C
- scale (to the . 01 of a gram)
Supplies:
- Methanol - get it from a hotrod shop or go cart place 99% pure
- Lye - Red Devil from the store
- Sulfuic acid - 95% pure or better
Happy reading. I know this stuff works in engines of all sorts. There's a local rock products company that runs a fleet of dump trucks on 100% pure biodiesel. Costs the owner an extra 20 to 60 cents per gallon (he said about 350,000/year) to buy the stuff. He receives no tax breaks at all. He and his wife both have asthma and he didn't want to contribute to the air problems.....
