Went for a test drive yesterday and an old repair to Battery wire where it connect to terminal on alternator failed. Problem is wire is now too short. I would like to run a new slightly heavier gauge wire from Alt bat terminal to fuse terminal in main relay box following harness.
My question is. The molded connector that mounts to alternator with the field,Ground and Bat wires in it.
Does it serve any purpose other than to correctly connect all wire to alternator in proper spots.
My guess is that is its sole purpose.
Truck in question is a 96 3500 Diesel.
Thanks. Kim
Thanks. Kim
