I just replaced my alternator brushes because starting a few months ago I noticed my lights slightly fluctuating now and then in an erratic pattern (including dome light so not switch). They were not dimming like when the grids come on at start up but less. The end collector ring where the end brush rides was quite worn with a deep groove and the other one was perfect (hope it runs ok for a while). The brushes were worn to the point they were just barely making contact so I'm sure glad I did this now. The truck has 242,411 miles on the clock. I sure hope this fixes the problem.
while the belt was off I also removed the belt tensioner and greased up both bearings. They were still tight and smooth but dry. Just thought I would share my two PM items for the day.
Admin, sorry I meant for this post to go under 12 valve engine and transmission. Could you move it please? Thanks
