Engine/Transmission (1998.5 - 2002) Alternator Not Charging At Idle
Engine/Transmission (1994 - 1998) KDP...Claims Another!!!
Engine/Transmission (1994 - 1998) High Fuel Pressure on a 7100
CumminsAholic
The alternator on my truck has started to not charge when the truck is at idle. It's fine unless I have something on like my headlights or amp for my subs. If I come up to a stop sign and let off the throttle, the battery gauge drops and the lights dim, but as soon as I start to take off the gauge goes back up and the lights brighten up.
Do you guys think I need a alternator rebuild kit or could it be something else like the crank position sensor? Everything else works good including the tach so I don't think it's the cps, I replaced that a couple years ago anyways. The truck has about 58k on it.
TIA
Corey
