Engine/Transmission (1998.5 - 2002) alternator
Engine/Transmission (1998.5 - 2002) Ring gear?
It may have always been like this, and I just never noticed. But, Ive noticed recently that, when I first start the truck, the alternator needle is to the left, almost right on the low "normal" hash mark. After a few seconds, it goes right to the middle where it should be. I hope this isnt an indication of the alternator going bad. Can anyone enlighten me ?
Thanks,
TRat
Its your intake grid heater cycling on and off ,---"NORMAL"---all do this,every time you start your truck in cooler weather. Should last fore about 3 min. Do a search on the subject and be prepared to read for hours.
Thanks,
I thought of that, and thats probably it. But, I dont remember it doing that before, and I would have expected the needle to bounce up and down, rather than just starting out low and then going to normal. Also, I had the block heater plugged in all night (I dont know if that makes a difference)
TRat
Mine moves slowly back and forth,even affects the fuel pump(Airdog) pressure by about a couple of PSI from the current draw of the grid heater. When i first bought this ride i called the dealer and asked what the heck is going on ---this from a gasser guy before my diesel. Oh YES and pre TDR days too.
it is not the alternator going bad... the reason you haven't seen it before is because the batteries are probably getting a little old and weaker. the grid heaters consume such a large amount of power that the alternator cannot supply it all... therefore the batteries act as a reserve to supply this power. when the heaters cycle on you see this as a lower voltage event on your meter. with a new set of batteries you wont see as much variation. keep in mind though... it DOES NOT mean you need new batteries. I ran my stock batteries for 9 years!!!
Thanks,
Batteries also occurred to me. My batteries are 6 years old now. If it was summer, I might not worry. But, I think its going to get cold this winter. And if I go up to the mountains, it might be a good idea to have batteries that I can depend on.
TRat
