The Dodge version of the AAM looked the same as the GM that Mag Hytec already had a cover for. However, they later noticed that the housing was cast a little differently and the o-ring traveled too close to the inside edge of the sealing surface on the Dodge. Hence some early covers leaked. They have fixed that. The fact that Mag does not use the top or bottom bolt is not related. I always use RTV because the cover will not come off periodically. I use the drain plug to change lube. Maybe it is excessive to use RTV with the o-ring, but I don't get any leaks, either.
