always alittle more
Oil bypass favorites?
Opinion on new engine and SMARTY?
New member here . So far its great ! I have a 04 2500 crew cab 4x4, automatic. It has 4. 10 gears,leveling kit , 305 tires, k&n filter and a banks 6 gun with power pda. It runs well but i would like to take the next step. The truck is driven for pleasure so i dont have count on it everday. any input would be great . THANKS
Hi, I've got a 04 2500 with the six gun and speedloader and was looking into the power pda, Is it worth the extra money or should I just get a set of gauges? Can you tell a differance in the level 7 mode, and how much of a differance?
I can tell a differnce in level 7 . Level 7 feels like going from level 1 to level 3. I like the power pda because u can pick different things to monitor. Also if need to b u can also clear codes. I have done some reading on here and it seems alot of people cant stand banks. I so far have not had any trouble with it or them. The only complaint i have is i would like to see a little smoke. But hey " SMOKES NOT EVERTHING "
You can Stack the PowerPDA with the T-Dog or equivalent,Pump(s), Rail,Trans,Injectors, Turbo, The more power=lighter wallet.
first think about how much hp you want to make and how much you can spend but start with necessities like guages, exahust, intake, trans, and then move to the fun stuff like turbos, injectors, ect. if you don't you will blow up your trans or engine and have nothing left for a new one. a little more can be very addicting good luck.
