Am I in Regen?
Trade for '06 5.9L?
Getting new turbo tomorrow
The boost thing makes no sense. Judging by the EGT temps, I'd say yes. And wow do the pickups run hotter than the Chassis cabs. Mine won't hit 1200* pulling 30K uphill, regen or not.
What are you using for gauges?
Gages Are
My gage set are Pricol Optix. EGT is 0-1600 F. Sensor is drilled centered in exhaust manifold. I see numbers over 1200 when under load. Normally not at 1200 with no load.
I am running the same gages that you are and I have installed my probe in the same location. My truck with the EGR plugged in will run between 1000F and 1350F when in regen. I have seen 1350F when pulling my 5er up hill in SD last summer but never higher then 1350F. I have since unplugged the EGR and when I regen mine will be 200F lower in Temp. My boost will always be around 3 to 5 PSI when I am in regen. When I was pulling uphill and regening I was around 10 to 15 PSI boost pressure.
I would check your boost gage or were you located your pick-up. You should always show some boost pressure when the truck is running at 60 MPH. Just my $0. 02
