American Axel Bearing Failure
Bedliner Repair?
steering HELP?
I recently had a bearing failure in my rear axel "American Axel" on my 2004, 3500 4X4. I thought I would pass this along in case some one out there may experience the same problem. Suddenly while in San Diego, CA on a trip I noticed a chattering noise coming from the rear of the truck. I made arrangements with a local Dodge dealer to check it out, but before the appointment (three days later) the noise almost completely went away so I canceled the appointment. A couple weeks later I thought I better have them check it out anyway since I would soon be towing our 10,000 LB trailer back to Ohio and didn't want to have any catastrophic failures along the road.
I took the truck to Rancho Dodge in San Diego and they replaced the rear drive shafts and center carrier bearing which included new universal joints. But the noise was still there.
To make a long story short, I towed the trailer for another 10,000 miles into Oregon and back to San Diego then back home to Ohio. The noise increased some but never got extremely noticeable. Once home I took it to my local Dodge dealer, Greenwood Automotive in Cortland Ohio. I explained my situation to Doug the service manager and he immediately went out into the parking lot and removed the fill plug from the rear differential and found a ton of metal in the oil. Upon tear down of the rear end he found the right side differential case roller bearing had a roller that split in half lengthwise. It is unbelievable that the bearing didn't totally fail and size up on the way home. Thank God for the power train warranty since the total bill came to $1,800. 00 for all new bearings, seals, gaskets and differential carrier plus labor.
Moral of the story is that if you hear a noise that resembles a wheel bearing noise coming from the rear axel... ..... check the fill plug for metal. If Rancho would have done this little diagnostic test, it would have been fixed there. Doug didn't pull the bearing off the old carrier, but it would have been interesting to see if it was a China made bearing or not!!
This is the first rear axle bearing failure I've read on this forum... . I've got 3 trucks, 04, 04. 5 and a 05, with the 04 at 240K miles and the other 2 a little under a 100K..... we've had u-joint problems and only change the rear end oil at 75K intervals, and have had no metal in the oil.....
I'm glad you found it before it failed..... I had a local tire dealer over tighten a set of axle bearings on our 94 after changing some studs..... it ran like 40 miles before the axle seized and broke... . welded the bearings to the shaft and he paid for the rental truck and the repair... .
I suppose it just happened to be one of those one in a million failures. What really kills me is that years ago the same oil stayed in the rear end from cradle to grave, but with this truck I have faithfully changed it every 15,000 miles, just like the owners manual says!! Maybe that's the problem? I also used DC synthetic oil just to make sure there wouldn't be any warranty problems. It had to be a faulty bearing and it just took about 55,000 miles to fail.
With the way some people change the gear oil I am surprised we don't read about more. Drain it but don't use any type of cleaner in there, if concerned use fresh oil to rinse. Every time you open it up you take a chance of something getting in there. Work clean but don't degrease the internals.
Gary -- the oils of today have to handle much more pressure, temperature, HP, and torque over what we saw just 20 years ago... . thats the key here...
