anybody use one of these? a buddy just turned into a dealer for 'em, and wants me to start using one. it's a dual density foam thing. any thoughts?
thanks
dave
thanks
dave
Vaughn MacKenzie said:I was another bad-luck-with-K&N-dirt-on-impeller-went-Amsoil-solved-my-problem guy. I was happy with the Amsoil. Since the big air filter comparo test posted elsewhere showed double foam filters like Amsoil and Uni clog up and get restrictive pretty fast they should be cleaned pretty often, but I thought the Amsoil was easy to clean.
Vaughn
Vaughn MacKenzie said:Sounds logical to me Wayne. I've run the Amsoil filter in my '01 and '03 and it felt noticeably freer flowing than the stock filter, and when I went from the K&N to Amsoil on my '01 it felt the same, no change in EGTs. It also seemed to be flowing fine when it got pretty caked with dirt. I was running about 325hp with both trucks, which isn't a ton of power but enough to notice a difference IMO.
The test is here if you haven't seen it. I didn't read the fine print to see if it indicated what particle size of dirt was used. http://home.usadatanet.net/~jbplock/ISO5011/SPICER.htm
Oly said:Have used Amsoil's stock replacement, IMHO it was a PITA to clean and re-oil properly. You're supposed to be able to use Simple Green to clean it, but after several attempts, mine was still dirty. Getting it re-oiled by pour and squeeze with a permanently affixed metal screen in it - too much hassle. AFE now for me, use what you feel is best for you.
Oly,Oly said:Well, if there had been directions in the box with the filter, I would have read them. Since there were none, the dealer who sold it to me said simple green was the suggested cleaning agent.
Any smart suggestions how to work around the bonded expanded metal screen in the filter?
