Darren,
Nice clean set up!
Two questions: 1) What is the valve at the oil fill cap?
2) The feed to the filter is tapped into the top of the factory full flow filter? Or do you have an adaptor to the original factory full flow port?
(I guess that's really three questions!)
Thanks,
Eddie
I removed the plug off the top of the full flow filter housing, installed a 90 degree elbow and routed that to the bypass filter. If you look at the picture of the return line to the oil cap you will see a steel plug used on the piece the valve is attached to, that is the plug from the full flow filter housing. As for the valve, that is so I can take a sample for oil analysis.
