I have an Amsoil Dual Remote Bypass system installed and just switched to their Series 3000 5W-30 HDD synthetic at the last oil change interval (prior to that I was using Amsoil 15W-40 HDD&M). I have adopted the following oil change/filter plan: full flow filter at 7. 5k (+ oil analysis and 1. 5 qts. of makeup oil), oil, full flow filter and bypass filter at 15k (+ oil analysis). I know many go longer however, I feel it is better to err on the safe side... no offense Amsoilman (I'm new to this extended drain thing... I've known about it for many years, you know, it's the old dog, new tricks thing
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass, Optima Yellow Tops, DD3s and DD TTPM, Aeroquip AQP braided s/s fuel hoses, Banks High-Ram intake manifold and 14 cm2 turbine housing w/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
NRA Life (Patron) member
