Amsoil dual bypass growl
Centrifugle Oil Filter ?
I need a transmission!!!
I did a search and see that some other people are having the growl I do from the amsoil dual bypass. It is mounted by the passenger battery.
Did anyone come up with a simple fix? Did you move it? the noise sounds like an old am radio turned up and just changes pitch due to rpm, its really annoying
My quick and easy (although not cheap) fix was to switch to the single by pass. There is no noise and works just fine for me. I'm sure that there is something esle that can be done, this subject is pretty well covered here and I'm sure someone else can chime in with info.
Check with Wayne (amsoilman on TDR) he should be able to help.
J-
Check and make sure that the hoses are not touching anything. When I put my system on. one of the hoses was just touching something that caused a terrible noise. At the time I thought that it was the system but it turned out to the the hose vibrating. Moved the hose over just a little and it has been noise free for over a year.
Rick
