Amsoil part numbers?
Brake controllers
Profile Plus Bug Deflector
I am new to the TDR and diesels. I have been using Redline oil since 1977 with great results. I am thinking of switching to Amsoil due to cost and availability in my area. Can anyone supply me with the correct Amsoil product #s for a 2001 6 speed w/HO Cummins? I would like to know:
a) Engine oil
b) transmission oil
c) Transfer case oil
d) Front Diff oil
e) Rear diff oil
f) Air filter
Thanks!
2001 HO 6 speed Regular Cab SLT 4x4 2500. Used for the daily/weekend grind and sneaking away to some secret Baja beaches toting a cabover
Amsoil product #s for a 2001 6 speed w/ Cummins.
(a) Engine oil =Either the Series 3000 5W-30, Stock # HDD or the 15W-40 Stock #AME oils. If you want Gallons, you simply add a 04 to the Stock numbers. If you want Qts. you add a 01 to the stock numbers. The 04 will give you 4ea. 1 Gallon containers. The 01 would give you 12 individualQuart containers. A QT at the end would give you 1 individual Quart container.
(b) transmission oil=The series 3000 HDD 5W-30 oil would be the one to choose.
(c) Transfer case oil=ATF oil. Stock #ATF. Just add Qt. to it for individual qts.
(d) Front Diff oil=Gear lube. 75W-90 Series 2000 Stock #TGR Just add Qt to the end to get Quarts. A 01 would give you 12 quarts.
(e) Rear diff oil=Gear oil. Same as above.
(f) Air filter=Stock # TS-106.
Hope this helps.
Wayne
amsoilman
94'SLT 4X4 AT/White in color. Factory Tow Hooks & Running Boards. Amsoil By-Pass filter, Amsoil Air cleaner,and all fluids are Amsoil. Optima "Red Top" batteries.
BD exhaust Brake, BD Torque Lock, BD Torque Converter, Dr. Performance Stage II Injection Pump. Mag-Hytec Diff Cover,Mag-Hytec Transmission Pan, Isspro Pyro, Boost,Oil temp Gauges mounted in 3 Gauge post mount. One gauge monitors Engine Oil, Trans, Diff. Temps.
[This message has been edited by amsoilman (edited 04-10-2000). ]
