roperteacher said:you know, I am not sure of the exact component that was grinding, it just was! When I had it changed out they used the suck out method, not taking the cover off. The AMSOIL that was getting sucked out looked OK, but then again it was only 3,000 miles old. I didn't want to see what was inside. . LOLOLOL Since it only did it when turning corners and pulling, and had only done it for a short time, I figured it was OK. When I called my dealer he said " When it breaks, we'll fix it" We can't slap on new parts just cause". . SO thats what I am doing. I have 85,000 more miles of warranty. If she quits, they fix it. . But since putting in the valvoline, PERFECT... . not grinding what so ever. I used to have a "Howl" between 65-70 MPH... now that quit too! Very nice!
DPKetchum said:Has anyone called Amsoil to inquire?They have a Tech help line.
GerryDrake said:In changing to the Mag-Hytec and Amsoil Series 2000 75W-90, I jacked up each wheel and let 'em drain for about 1/2 hour per side, then wiped out the bottom as much as I could. When I filled it, I brought it right up to the upper of the two marks, figuring replacing what had drained out from the axle tubes would likely bring it down a bit. Today I drove it around for 10 or 15 miles, including a few figure 8's in a parking lot. Now the dipstick (I love having that) shows exactly midway between the HI and the LO marks. Interestingly, the dipstick's magnet had gathered a little ring of powder, presumable washed from the interior of the diff. I guess I should check and clean it periodically. Hopefully after a few 'washes' it will stop showing up...
