Update
After getting most all the issues and electrical gremlins cured and finally getting a little road time. The truck has chatter problems in the rear end when powering up and around a sharp turn on a hill (switchback). It is also noticeable when driving in town where you are required to make a sharp turn under power. I added one tube of friction modifier to the Severe Gear oil upon installation. I am going to call Amsoil, Monday, and see what they recommend? More Friction Modifier? I checked the tire pressure and matched the two rear tires very closely @ 50# running empty.
BTW, The mileage has not suffered in the least, still 19+ with mixed driving including 4X4, using Bio Diesel mixed with #2, winter blend. Will do more thorough mileage check after chatter problem is settled. GregH
