Amsoil Trans fluid question?
Gen set to power engine block heater
HY35 upgrade ?
This is a question for all you oilmen(or women), if Dexron is not good for our auto transmissions, how can a synthetic version of Dexron be ok now, when just a few months ago we needed to buy a special version of Amsoil just for our trucks? Amsoil has done away with the +4 that I put in my trans, now I need to find out what to use in a few more months when it needs to be changed.
Thank you for your input.
HAPPY RAMMIN
Caleb
1993 LE W250 4x4 CC,Auto,3. 5's,Limited slip. Diamondplate,K&N,Egt,Boost,trans temp VDO Vision series, BD 3 1/2" Exhaust, 16cm housing,Mag Hytec Diff+ Trans pans,Transgo TFOD shift kit,Roadmaster Active Suspension.
Hi Caleb, Amsoil was able to engineer a synthetic ATF to meet ALL performance criteria specified by all major manufacturers. According to Amsoil the new ATF is certified for use in the 47REs and all prior derivatives.
. . gonna miss ya bringin' up the rear with Rob.
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps, Mag-Hytec diff. cover & trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, VDO Vision gauges, Dynamat, '00 Sport grille & valve cover, '00 Sport headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake and TorqLoc, Prime-Loc, Amsoil Dual Remote Bypass, Optima Yellow Tops, Bosch 275s, VA CPC, (censored), Aeroquip braided s/s fuel lines, Banks 14 cm2 turbine housing/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , BD V10/Cummins hybrid TC & valve body, BD trans. front pump & PressureLoc, Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
Just like John said, the new stuff meets all the criteria required by the major manufacturers. Check out the label or the specifications online at amsoil.com.
I have about 10 qts of the +4 left, but you can have it if you really have to have that. When it's gone, I'll be using the new stuff.
http://www.amsoil.com/products/atf.html
'95 2500 SLT ClubCab, automatic, 3. 54 LSD
