Originally posted by PGoble
Here is a pic of the SRT-10 Hood & Bumper on mine.
Originally posted by NJTackle
Where did you get the hood and how much????
Originally posted by SRadke
Can you order them in the proper color or did all you guys have them painted?
-Scott
Originally posted by OT-OF-HERE!!
Question, since you obviously have this on your truck, if it is set up as true ram-air will you pick up enough moisture driving in the rain that it would cause any problems with intake or turbo,. . or did you block it off? If you block it off I thought of using a thin piece of black plexiglass to fit inside the hood just behind the vented opening/cowl. Tks
You can order the hood through your local dealer, I think it costs around $500.
No, they do not come pre-painted. They come primered in flat black (like the underside of your stock hood), and you must have them painted.
Well, actually the scoop was not designed as a true "functional" ram air. In the SRT-10 truck is just vents the engine compartment and has nothing to do with air induction system. At this time, I have not done anything to modify it. I have been planning on blocking it off during the winter (your plexiglass idea would work well), or using it as a secondary feed to the air filter. I think it would work well to keep a fresh air supply coming, but it would take a significant amount of work to custom build the duct work and you would have to design in some kind of water drain/filter system.
Pete
Originally posted by Crunch
How long before you route the intake for your BHAF to the scoop. That and post pictures of the conversion so we can do the same thing.
Do you notice any problems running in the rain? What did you do with the underhood silencing blanket?
OT-OF-HERE!! said:PGoble,
It doesn't have a direct feed ram air tube or anything to the air intake, Pat
OT-OF-HERE!! said:Do you notice any problems running in the rain? What did you do with the underhood silencing blanket?
