The final analysis - 20,000 miles!
This is the end of my extended oil test - further down are analysis done on the Delo 400 15/40 when I reached the goal of 20,000 miles on the oil.
As pointed out in the beginning of this "test", it was done for 3 basic reasons:
1. To attempt to establish and show that you don't HAVE to use high priced synthetics to employ extended drains, as many do to recover the substantially higher cost of the synthetics.
2. To show that bypass filtration will greatly assist in normal, and extended oil usage.
3. That those nasty K&N air filters, when installed and maintained properly, WILL deliver excellent filtering capability. Ditto the Frantz toilet paper bypass oil filters.
I also want to again post the typical analysis of *NEW*, unused Delo to use as a baseline for analysis of used oil at various mileages - please be aware that during my test run, Chevron modified it's Delo formulation to include Molybdenum and Boron - excellent anti-wear additives.
From Blackstone Labs, 5/10/04
Chevron Delo 400 15W40 CI-4
Al-1
Iron-2
Lead-1
Silicon-5
Sodium-1Calcium-3476
Magnesium-6
Phos-1190
Zinc-1329
Vis@210F-80. 5
Flashpoint-450F
TBN-not tested
Compare those NEW numbers with the 20,000 mile numbers down below!
And, for those interested, you can read specs/analysis of the new virgin Delo 400 with Moly and Boron added, here:
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=11;t=000240
My intervening reports at various points are posted further above, and for this post, I am including analysis reports from both Cat and Blackstone on oil samples taken at the same 20,000 mile point.
Here's the Cat sample:
NOTE: Click on images to restore size for easiest reading!
WOW! That's TERRIFIC - but wait, maybe a bit TOO good?
Here's the analysis done by Blackstone on the SAME oil:
And here's what Blackstone had to say about the above analysis:
I won't attempt a guess as to WHY Cat's analysis seems so far out in left field - I've used Cat before with results that closely tracked Blackstone's - but THIS one sure doesn't - and the Blackstone report follows along quite well as compared with the others they have done in this test. A pity in a way - I still have 2 unused prepaid Cat sample Kits available - but don't trust the Boise facility after this test. And Blackstone's prices are too high for regular use, as far as I am concerned.
Note that Silicone (dirt) percentages have been excellent in the earlier section of this test - and DID improve (at least no further increase!) after the switch to the BHAF in the last 7000 miles or so - but NOTHING to complain about with the previous K&N as far as I am concerned!
Because the Frantz TP filter I use recommends cartridge changes at about 2000 miles use, I have changed cartridges about 10 times during this run - and added the required quart of makeup oil each cartridge change - for about 10 quarts total over 20,000 miles. TP elements cost about 80 cents each - and the Delo runs me about $1. 60 a quart where I usually buy it - that's about $16 worth of oil, and about $8 for filters, plus one Fleetguard 3894 back along the line. A total of a bit over $32 in lube and filters in 20,000 miles ain't bad, as compared to "normal" changes - and MOST of those miles were pretty hard, partly RV towing, and a half-dozen well loaded trips as we made our move from California here to the new place in eastern Oregon
SO - there's the data, check it out and draw your own conclusions - but for MY money, I remain fully convinced:
You don't HAVE to use fancy high-priced synthetics for extended oil use, and combined with my GOOD bypass filter, MY oil coulda easily just kept on going, just like that "Energizer Bunny"!
