Hi,
Looking for some advice. This has to be at least one of the ten dumbest things I have done, this year anyway. Was replacing the fluids in my 04 Ram in preperation for the winter. It has 64,000mi and is a 6spd with the NV271 Transfer Case. I had just replaced the Transfer Case fluid 20K miles ago. I thought I would draw a sample of fluid out of the Case to see how it looked. I have a syringe with a piece of Tygon hose on the end that I use for this. Sure enough the piece of Tygon slipped off the syringe and fell down into the Transfer Case. It was 1/4OD Tygon about 2" long. I can't find it from the filler plug. The drain plug isn't very open on these. There is an obstruction in the opening from a rib that is part of the Case casting. Here is my dilema. Do I rip apart the Transfer Case to get it out or will it just get chopped up and not do any harm. I have no reason to rip the case apart other than to retrieve the hose. I wasn't real concerned about it doing damage. I was thinking it would probably just get chopped up. Then I see there is a pump listed in the shop manual. I thought it was just splash oiled. I got concerned that it might affect the pump. I have no issues with the Clutch/Trans/Transfer Case so ripping the Case apart would be solely to retrieve the piece of Tygon. What does advice is out there.
