If you have read any of my other posts you probably know I am a little nuts when it comes to the fuel system on my truck. I wanted a manifold that I could install a pressure sender, a pressure switch, and a temperature sender as well as a "quick" bleed valve for use after filter changes. Found an aluminum anodized manifold with 3/8" npt in and out and (5) 1/8" ports along with mounting holes. My plan is to mount this to the OEM filter housing bracket which now serves no purpose. Anyone see any problem with this?? cost was only $11.
Thanks
Thanks
