well fellas, guess what? I finally did the 366! thanks to the instructions Pastor Bob made up, and a lot of patients, its all done. i havnet drove the truck yet, i finished everything last night about 2a. m. and just got home from church now, so i havent run in on the road yet. that will be fun. but i got the idle all set and everything. that index on the throttle was a PAIN. i took a picture, and whatnot, but i couldnt decide between 2 teeth on the gear. but between that and the idle screw, shes set back at bout 850rpms. it started off at 1200, then i droped it a tooth, took it to 400rpms, that was a little exciting
sounded like i had a cam in it.
Matt, ill be sure to let you know how it does, sence i havnt adjusted the fuel screw or anything. so you can tell what a 366 does in a stock pump.
Now i have a question about griding the cone... after taking it out and seeing it, where/what do you grind. thats the next thing im going to do, along with the fuel screw.
thanks yall. ill get pictures up from the install soon, there are some pretty good ones. take it easy, Jimmy
