I just finished the install a bit ago and was expecting to have to go back in and adjust. But the truck seems to run fine. It does idle just a bit higher, around 900, is this too high?.
If the springs were too tight, I would have a flutter in the engine at some point, is this correct? What would be the indication if they were too loose?
RPM range is significantly greater, But it does seem like slightly less low end power. Is this normal?
I plan to do the governer lever adjustment in the next few days, and possibly idle adjustment.
Thanks for any input???
