Another A/C problem
Air Conditioner evap. drain causes dry rot in suspension
Custom exhaust flanges baby!
2 ac vents on driver side are cold but 2 for pass are hot. :confused:
This is a single control system.
Any idea as to where to start.
I dread taking the dash and heater box out:mad:
On my 96 it took me 2 days.
Our trucks have a split evaporator and you are low on charge and only saturating one evap, my truck does the same thing when I get low on charge.
Thanks for the help daytripper.
I will check the charge later this weekend and let you all know how it went
low charge... ... My 05 has done this every year since new, every year had warranty "repair" (well, extended warranty repair now), works pretty good rest of summer. Not sure how to get a proper repair done.
Thanks guys you were rite on it was low and is cold as heck now with a charge. :)
Having a dodge ram without a tdr subscription would be hell:eek:
Have tech add tracer dye to ac system when adding freon. Dye will be visible where leak is. Sometimes need black light to see dye if leak is small. John. :)
